setting micrologix output
cdnrookie
Apr 2013
Canada
112
Micrologix 1000
Dumb question but I can find the answer anywhere
Taking the 24v DC power to the output side, can I set it to output 9v? That's what my led`s require?
Thanks in advance
cdnrookie,
the only dumb question is the one not asked.
unfortunately the answer is no.
24volts is what you will get unless you use an inline resistor and do a voltage divider to get your 9 volts.
may i suggest buying a power supply and wire it to the plc outputs. the plus can go to the common terminal and the negative can ne on the terminal strip.
regards,
james
Greetings,
if you input 24 volts you will get 24 volts out. I will suggest to use a 7809 Voltage regulator. very easy to install input = pin1, ground = pin2 and output = pin3. The component will be facing you, so that you can read the numbers. then the out put of the regulator will be connected to your output in the plc.
If this is a classroom PLC lab, and you have a variable DC power supply available, then yes, you can set it to 9 volts to take care of your PLC Input voltage level. But your PLC may still need a 24 VDC (or some other voltage) for its operating voltage). You might use TWO power supplies to handle this problem, one set down to 9 volts DC. As Mickey said, a 9-volt battery is a good classroom solution for one or two low-powered sensors.
Can you tell us the complete catalog number of your ML1000?
A unit with solid state outputs may have enough leakage through the solid state outputs to keep the led's on even though the outputs are off. Something to consider.
Thanks guys,
It's not a school assignment, I was given a micrologix 1000 to play with and have designed an electronic target program for my son to practice his shots on.
The targets are made and ready for wiring and the program works fairly well.
It has three settings, basic, int. And advanced
I'm sure the program is way more complicated than it should be, but I'm enjoying the practice
I'll check the full catalog number later and post
Thanks for all the advice
I'm using the RTC in a MicroLogix 1400 and I want the operator to be able to set the date and time via an HMI (brand irrelevant). The HMI can't...
9,291
I see you can set the IP Address of the Micrologix through the LCD screen (nicely done Rockwell). Is there a way to set the IP through tags? I'd...
9,739
7,325
Hello I have a new Micrologix 1000 1761-L32AWA PLC and I have RSlogix 500 and RSlinx. I need step by step instructions to set up the system. I run...
2,379
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
849
