Help setting up a micrologix & software!!
May 2004
54
Hello I have a new Micrologix 1000 1761-L32AWA PLC and I have RSlogix 500 and RSlinx. I need step by step instructions to set up the system. I run Windows XP. If you could help with as muck detail it would help out alot. I seem to be having a communication problem. When I click on RSWHO in RSLinx a window pops up saying
RSWHO: Failed to open project!
I also got a message when I clicked on whoactivegoonline from the Comms menu in RSLogix that said:
no response from processor at selected path/node! the target node is not an SLC-500 or Micrologix controller!
I think I'm close I just need a little help. If you could help I would be greatfull. You could email me at [email protected] or reply here what ever is easyer. Thanks John
Every time you click RSWho?
Have you attempted to configure a driver?
If so, what happens?
What version RSLinx?
What version RSLogix?
Depending on what version of RSLinx you have, I would upgrade to the newest version.
If nothing else works, I would try un-installing and re-installing RSLinx.
Get back to us with some more Info.
If Arik's guide doesn't sort it out for you, then there are a few other things that could have gone wrong:
1. Have you set up a PIC/DH485 driver in RSLinx ? I have heard that it can interfere with other drivers (such as DF1). You must remove it and reboot the PC to allow access to the COM port.
2. The COM port is hooked by some other application.
3. If it is a laptop, then powersaving schemes can lower the voltage on the COM port. Try to disable all power saving.
4. Do you have the right online cable. It should be a 1761-CBL-PM02.
you can try deleting HARMONY.RSH ...
I've seen this one before and I THINK that "method 1." is what we did to correct it ...
Knowledgebase P9020
this is along the same lines as one of the links Marc posted but with a little more current date ...
1. Shut down RSLinx, delete HARMONY.RSH, restart the computer, restart RSLinx.
note: if this one doesn't help, there are some more links at the bottom of the knowledgebase page ... please let us know what you finally come up with ...
I am working on setting up my own 1756 B series PLC rack, power supply 1756-PB75 /B, 1606-XLS480E -redundant 24 DC power supply, controller...
4,317
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,373
Hi everyone! First time posting to this, so should give you a bit of background info on myself to explain the situation i'm in. I am a beginner...
1,579
I am new to compactlogix 1769 L30ERM PLC. when I was upgrading firmware to version 30 through control flash flowing error came. it is; and also...
3,035
Hi experts! As always I come seeking your expert advice once more I need help using Adroit, specifically trying to use databases I have a...
2,107
