Setting offset for an analog input on Logix5000 project
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I have a compact logix control that is receiving an analog input from a T/C. The program is written in FBD which I am not real experienced with but it is simple enough to understand. What I would like to know is, I have an analog scale (Ana_Scale_00) function block that is reading in the data. Using a temp simulator my reading is off by a few degrees. I would like to know if there is something in the function block that would allow me to offset the difference or do I need to add a match block that will take my input and subtract it out? Thank you
I don't know if the Ana_Scale_00 FBD has a scale factor that would easily shift the temperature a few degrees. This should bump you up so maybe somebody else will help answer the question.
Hi all! I need to adjust Offset and Gain on Analoge out card A62DA... Will the CPU (mitsubishi A1) stop when short circuiting 1 & 2 (Test)?? Will...
1,698
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
81
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
86
