SEW Eurodrive & HMI choice?
kvogel
Jan 2011
Colorado
106
Has anyone here sucessfully used a 3rd party HMI with a SEW Eurodrive MoviPLC? I am trying to develop a sytem using MovidriveB inverters and a Movi-PLC (DHR 21B) and and have had no luck with either of my two go to HMI's (Idec & Weintek) being able to connect via Modbus TCP. It appears that the SEW modbus supports only function codes 3, 16 & 23 and the HMI's are using different FC's to read & write (3 & 10)
If you have used an HMI with an SEW PLC then I would greatly appreciate a recomendation (but only if you know it works)
The PLC also supports EthernetIP but I havn't looked to see it either of my HMI's have a compatible driver yet. That's on the plan for next week.
Thanks in advance
Ken
3 & 10 sound like Hex... 0x03 is the same in hex and decimal but 0x10 = 16decimal , for Modbus function code 16 (write multiple registers, per the spec http://www.modbus.org/docs/Modbus_Application_Protocol_V1_1b3.pdf). I think I played with some SEW hardware on CAN a while back so I am of no help, except to note that those function codes look OK from here (far, far, away). Do you have a Wireshark trace to see what is happening? It cuts the problem in half - if the queries are issued we can look at the response and see if there is an error. Also sometimes devices require specific UnitIDs. If you are using 255, maybe try something else, like 0? Also watch for the off-by-one register selection.
Robert,
Thanks for your tip on wireshark. This is a must have tool for any communication troubleshooting.
One of the manuals wasn't clear in it's use of decimal and hex designations, so I missed that there was a base difference
SEW uses an odd protocol for the process data exchange via modbus. Unless I'm missing something, the read and write reference code must always be 4 and the 64 registers are accessed by their respective place in the data word mapping.
If I change the modbus register address the communications fails, but I can write a script in the HMI to properly load the data table and exchange up to 64 words.
Thanks again
Ken
Good Evening , I took notice that the majority of the gearboxes we have in our plant are SEW Eurodrive . I started wondering , of all the...
4,208
Hello I need to control a Sew Eurodrive MDX61b position (HI and LO) from a PLC S7-314-2DP with Ipos and I don't understand how to use the strong...
1,576
P512 is set for 4000, which is the max (I think), but i still have this error, and it won't reset. Is there a parameter that shows the actual...
1,115
Good Morning , We have been getting a number of F14 Encoder Faults on a SEW MoviDrive . I do not have the software to get the "sub-codes"...
3,022
I am looking at removing a UNIop MD03R-04 interface that is used to insert a setpoint for length into a MoviDrive MDX60A-00 from the PLC port of...
1,147
