SEW Movitools Help
bdatagcauto
Sep 2007
Alabama
Can anyone tell me why, when I try to access "shell" in manager, it gives a fault "wrong or missing BIN files at". That is all the info it will give. I am new to Movitools so any help here would be appreciated. The SEW website is not a good source of info. Thanks
Does it happen when you choose "OFFLINE" type of connection?
may be you have a corrupted BIN files of the movitools software? have you tried it remove and install it again?
Found the problem, it was in my software. Don't really know why, I have the same version from the same disk on two computers. One works and one doesn't. I'll reinstall tommorrow, see if it helps. Thanks for the advice.
I have a project setting up a MovidriveB, and using SEW Eurodrive in general, for the first time. The application is for a Hoist. I need to...
1,609
Dear members: Can anyone share old version of movitools 2.3 software for testing MDS60A sew drive?and how can I test motor without encoder in...
157
Hello guys, I have some SEW Drives connected to an Controllogix PLC thru Ethernet. I cant find where the PLC signals are assigned to the SEW...
748
Hi guys I have 2 machines with sew hmi, 4 movidrive units connected via Ethernet and I have seen that we don't have any back ups if they fail...
2,294
Machine A has a Siemens PLC and ABB robots. Machine B has a PC control and not ABB robots. We are making machine B like machine A. I have the...
3,745
