SFB 49 Pulse block " Need HELP"
Feb 2013
Alex-Egypt
Could some one show a simple example of how to use this block in order to generate a pulse of 500ms on and 500 ms off?
I tried to do this but i can't get any output from the Q0.0 terminal
You don't need a FB, enable the clock memory and you have bit 3 = 500mS on and 500mS off.
Bit of the Clock Memory Byte
Period Duration (s)
2.0
1.6
1.0
0.8
0.5
0.4
0.2
0.1
Frequency (Hz)
0.5
0.625
1.25
2.5
Hi I am using Siemens s7-300 and I amtrying to work out how to read the output data from a sfb 52 block. I have a IM151-8F CPU connected trough...
1,460
Hey any body tell me how i can program FM 350-2 through ET200M ..can i use SFB48 in my programing for this
2,065
Hi all in a SCL FB I've decalred some variables like this: VAR ShiftRegister:ARRAY [0..100] OF BOOL; ValvesOutputCMD: ARRAY...
1,639
A message with the following information appeared on the HMI: STOP Caused by PG stop operation or by SFB 20 "STOP" Previous operating mode: RUN...
2,037
can anyone plz guide me some information about SFB AND SFC
2,453
