Hi'
Can anyone tell me what is wrong here, I can't compile this code.
Thanks in advance.
Brian
Code:
FUNCTION_BLOCK FB10
VAR_INPUT
Step : BOOL;
END_VAR
VAR
// Static Variables
RET_VAL_1 : INT;
RET_VAL_2 : INT;
END_VAR
// Statement Section
IF step = 1 THEN
FILL(BVAL := P#DB11.DBX0.0 BYTE 32 // IN: ANY
,BLK := P#DB12.DBX0.0 BYTE 32 // OUT: ANY
RET_VAL_1); // INT
FILL(BVAL := P#DB12.DBX0.0 BYTE 32 // IN: ANY
,BLK := P#DB11.DBX0.0 BYTE 30 // OUT: ANY
RET_VAL_2); // INT
END_IF;
END_FUNCTION_BLOCK
Thanks in advance.
Brian
