SFC21 in SCl
BNA
Sep 2003
Give
117
Hi'
Can anyone tell me what is wrong here, I can't compile this code.
Code:
FUNCTION_BLOCK FB10
VAR_INPUT
    Step : BOOL;
END_VAR
VAR
    // Static Variables
RET_VAL_1 : INT;
RET_VAL_2 : INT;
END_VAR
    // Statement Section
    IF step = 1 THEN
    FILL(BVAL := P#DB11.DBX0.0 BYTE 32 // IN: ANY
         ,BLK := P#DB12.DBX0.0 BYTE 32 // OUT: ANY
         RET_VAL_1); // INT
    FILL(BVAL := P#DB12.DBX0.0 BYTE 32  // IN: ANY
          ,BLK := P#DB11.DBX0.0 BYTE 30  // OUT: ANY
          RET_VAL_2); // INT
     END_IF;
END_FUNCTION_BLOCK
Thanks in advance.
Brian
Constant is something that cant change. Like this:
Code:
Variable is something that can change, like :
Code:
MyAny
You need to declare your any's as variables and build them, you can use 'AT' for convenience.
Hi. I came from S7 and i have a problem trying to reset the value of some tags. In Siemens is To Easy reset a DB (With BLKMOV or FILL), in Rslogix...
3,047
Anyone tell me why this code comes up with an error, I'm trying to fill an array with a value, the array is in the stat section of the FB (60...
3,227
I am trying to reset all values in DB10 to 0. I think the best way to do this is using SFC21 the fill block. I made a copy of DB10 with all 0's...
9,861
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
Hi, I have an intermediate-advance knowledge of programming with TIA Porta in Ladder, would you recommend me to start learning SCL for it to...
583
