Shielded Ethernet Network Installation
naegely
May 2008
Florida
93
The following paragraph is from the AB ethernet cable selection guideline:
Shields help to reduce noise coupled to the balanced cables by providing a faraday shield
around the conductors. However this is countered in some cable designs by using poorly
balanced cable pairs. Shields can carry ground currents due to ground offsets with in the
building grounding system. These currents at worse case can cause equipment damage.
At the least, the currents can be disruptive to the network communications. EtherNet/IP
reduces the chance of ground loops by isolating the shield at one end of the channel from
ground. This is done through the use of an RC between the shield and local node ground
connection. The RC is always in the device end and not at the switch end. The switch end
of a shielded channel is always grounded if the switch is grounded.
Can someone tell me what the RC is? There is no definition in the document.
Thanks very much,
Rob
What do most do out there in regards to ethernet cabling? Buy pre-made cable lengths for use in panels? Buy a spool and crimp your own? If you...
29
7,582
Shielded ethernet cables with grounded connectors on both ends....is that not the same as grounding both sides of the drain wire in a 4-20mA...
1,912
Hy, can we use shielded ethernet cables for drive-cliq connection to sinamics s120 components? Will any problems happen? I contacted siemens...
4,255
Hi, Many analog sensors come with M12 connection and up to now for own uses and not so crutial meassurements I have used non shielded M12...
2,034
Good Morning , I have a quick project to do , I know it is not a good practice , but can you put a shielded 120 ac cable in the same...
5,303
