Shifting data over 1 bit
DannyD303
Nov 2016
Hingham, MA
30
Hello all,
What I want to do is take a word of data and move the bits over 1 bit.
So to keep it simple:
0001 0011 1100 0110
and move into different tag
0010 0111 1000 1100
I'm using Studio5000 Ver.30 and all of the examples I see for BSL are using Logix500
Any help would be great,
Thank you
BSL is still available in Logix 5000, and works essentially the same way as in Logix 500. If you want to check it out, just put a BSL on your rung, click on it and press F1. The help file generally has quite exhaustive worked examples.
Hello specialists! I am little bit concerned about transferring 4 chars to data block every time we receive positive edge. The thing is, I would...
2,230
Good day all! I am using a compact logic controller, L16ER, and I have an 8 position rotary table. I will try to explain the table positions as I...
2,203
I'm working on a conveyor type system where i have a part moving on a conveyor that i measure the length with sensors puts the floating point data...
17
6,924
Hello, Im trying to shift 110 bytes of data down by 10 bytes within the same datablock (data block is actually 110 bytes in size) so im...
20
11,289
Hi! I have an array of 300 part numbers (each is an ascii string of 2 DINT in size). I need to display the top part number at the first station...
4,480
