Shut down Server Procedure Scada
Abn
Nov 2019
Fl
37
I need to upgrade the ups on the FactoryTalk Scada Servers.
I have a primary server, secondary server and Historian server.
1) Is there a procedure to follow to shut down all of these servers?
2) Is there a procedure to follow to turn them on?
Regards
If it were me I would update the Secondary first, then the Primary, then the Historian
If the original programmer got his ducks in a row, you won't lose any data or have any downtime.
As Janner_10 says, shutdown one at a time and move over to the new UPS, starting with the secondary.
It may be worth taking things a step further, and install a bypass switch. That way in future you can work on the UPS without needing to shut everything down.
For our critical servers we install an automatic transfer switch so if the UPS fails, everything reverts back to mains automatically.
Thanks for the advice, I will recommend it.
I have a panelview plus 7,and often popup a messagebox"application servicesd.exe encountered a serious error and must shut down"I refreshed the...
1,073
This is slightly off-topic, but I figured I'd ask the community. I have an application where we're running a panel PC with Windows 7 Professional...
22
7,422
Hi, I just experienced something strange. I connected a Field PG (PG/PC adress 0) on a profibus network to monitor something in the field. I...
6,852
So I am wondering how many other troubleshooters force things on or write around things temporarily to get a machine running, then come back and...
36
12,874
There is a plant shutdown for around 5 months. We are planning to preserve the control system for maintenance reasons. Any standards for...
1,649
