sia project manager PG% V2
jude
Oct 2010
ontario
117
using a demo verion of Saia project manager sp2.0.150 I uploded a program from a PCD 3.M 5440.
It uploaded as a UPL file which the demo will not open, I used the disassembler and it changed it to a dsr file which the program opened as a partial il or structure text program which seems to be incomplete, From what I have read the demo should work as a full version for a period of 90 days. Anyone any ideas
Saia PG5.2
The demo version is a full version for 90 days. (standard libraries only)
What choices were made when you disassembled the file?
(listing, source files, single source files, block separated,block type separated etc)
When you disassemble your upl file, it may not be very readable, dependent on how it was programmed.
Normally you will need the source project.
you are right I needed the source file the supplers sent it to us on the 5th November and I was able to open and read it yeaterday
Thanks now do you know where I might find basic information on programming in this format , I am comfortable in Allen bradley but not with this and I need to get familiar so I can at least trouble shoot it
Thanks again
At the Saia support page: http://www.sbc-support.ch/
Look at product code index\PG5\PG5 2.0 (current version)\PG5 2.0 Suite
There is a programming manual for download. Besides the help is quite good if you open the files, place the cursor on the instruction or fupla box and press [F1]
The installation program also installs several programming examples in your project library.
Bardes
PG5 2.0 Suite
I am looking around for an Omron CP1H PLC and on ebay I find loads of them, used, shipping out of Korea, China, Hong Kong, claimed to be fully...
2,451
I am in urgent need of a CP343 (6GK7 343-1EX30-0EX0) for an installation in Russia. To speed things up i am looking to buy one directly in Russia...
2,236
An earthquake of 8.7 Richter has hit Aceh on Sumatra. A Tsunami is expected to hit almost the same areas as the catastrophic Tsunami of 2004...
1,530
Hello all and happy holidays Last year we moved a water chiller from a sister plant of ours. This unit has sat since that time. We are just...
4,475
Can anyone help with providing the correct color standard for single phase 240v AC in Malaysia? We've had a look around the web but can't find a...
22,721
