Siemen CP 340 Module Slow
cotang
Aug 2006
calgary
58
I am using the siemen CP 340 module to output a data packet consisting of a string of 10 characters. The problem i am facing is that with this module it seems like it takes one character at a time and outputs it. So in hyperterminal where I'm receiving the data, it looks like its scrolling the packet instead of displaying it all at once (or fast enough that it looks like all at once).
Is there a way to increase the speed or just output the entire packet with out doing it one character at a time?
In the Hardware configuration you have parameters for the card. Check the "dataflow settings" under transfer settings. Try setting this to none. Note that you must have the CP configuration program installed for the settings to show. The program comes with the card. It can also be downloaded from Siemens webpage.
Hello, I have an int value in my DB and I want to transmit that to hyperterminal. I can send something but it not showing up correctly. Example...
2,578
Has anyone ever got this message before? The drive will be running fine and for a couple days or a week then the control room will get the message...
572
Hi, I am logging tags every 24Hr in table view in siemens WinCC RT Professional. Every day at 7:00:03 AM a value is logged. WinCC takes value from...
17
3,594
Hi everyone. Please help me to upload program from S7-1200 with TIA v14. I created new project, go to Online tab, select Upload devices as new...
1,092
Hello Every one I am trying to connect the encoder with siemen's 300 plc but dont know how to do it... Could some one send me the connection of...
2,219
