SIEMENS 100U I/O module problems
cmngigi
Nov 2005
nairobi
I am trying to Re-activate a concrete mixing machine that has a siemens 100U cpu 103 fixed in it. I have the following items , a Siemens programmer PG720, Step 5 ver 7, S5 100U users manual.
The problem I am experiencing is that the CPU cannot "see" the Input and output modules when I perfom a "System Parameters " command.
I am not good in Siemens PLCs because my exposure has been mostly on A-B PLCs.
Can some one tell me how to configure the modules and what software to use. ?
The manuals on the S5 100U products don not show how to.
Please Help me out
Warm Regards
Charles.
Dear cmngigi,
I attach S5-100U manual.
If you want to check if a input works
you need to access it with test->Status Varible, but before you must activate online connection on File->Proyect->Adjust->Operation_Mode->On_Line.
Best regards,
Kelkoon
dear All, i am working on the step5 of Siemens. after successful upload program and going online but RLO data is not updating. In Tset>Status...
2,083
Hi, I have several 100U CPU's with either broken Run/Stop/Copy switches or broken off/on switchs. Does anyone have a source for replacement...
1,672
Hi all, I need to interface a Siemens S5-100U PLC part number 5ES5 103-8MA03 onto an Ethernet network. Are there any protocol converters...
1,709
We have an old system controlled by a siemens plc s5 with order no. 6es5 102-8ma02 we want use for this system operating panel siemens op25 but so...
2,900
What is the memory size for Siemens Simatic s5-100u-cpu 103? part no: 6es5103-8ma03 Is the memory for logic seperate from memory for data? What...
5,198
