Siemens 1500 and Fanuc robot
Casius
Jan 2014
Cluj-Napoca
Hello
Can someone help me please with a Siemens TIA (project in TIA is better) or Step 7 project to manage a Fanuc robot?
I want to see how the inputs/outputs are used and also how the programs are sent to robot.
Thank you!
:geek:
This is a very basic question. You would need to provide more detail.
There are multiple options.
1 - You could have discrete hard wiring between the two devices
2 - Field bus (whatever Fanuc supports Profinet, Profibus etc...)
There is also the possibility that safety is passed over the Fieldbus, I assume Fanuc supports that, but can not confirm.
Update
Hello
Thank you for your reply.
I'm going to use Profibus and Siemens 1500 CPU. I don't know the type of controller.
I need an example because I have read that the robot have different methods to select a program (PNS, Style, RSR, others).
I don't have the equipment but I can see how others manage this and be prepared.
Thank you!
Do you have any training in Fanuc robot?
Like you said, you can use PNS. The principle is that you will send bits (outputs) to the robots that correspond each to PNS command. You will be able to select the PNS program to start, be able to pause it, abort it, there are also security signals to send to allow the robot to move.
You should really try to get a hand on a FANUC manual. To use PNS you have to se the robot to remote control, instead of local.
FANUC supports fieldbus with the dedicated cards (PROFIBUS, PROFINET , ETHERNET IP).
Been fighting all morning with a stubborn HMI. It just won´t connect with the plc. attaching from settings. Have i missed anything? Both plc and...
325
Hello everyone, I need your help. At one of my company instalations we have GE90-70, and we're going to replace it with some newer PLC. I prefer...
524
Looking for options to write data to Siemens PLC. Looking for something closest to way we were doing it with AB PLC and excel sheet. Old way...
922
We've got very fast machine whose position controlled by interrupt OB35 set at 2ms. For position reading we use Temposonic connected to TM...
19
2,569
So, we have one servovalve that is very critical to machine operation and idea is (or was) to detect if valve gets disconnected from analog output...
2,955
