Siemens: 2-Wire current transmitters
BVG
Apr 2012
Ghent
Hello All
I am working on a project with allot of current transmitters. We are using an S7-1500 with the analog input card: 6ES7531-7KF00-0AB0.
All the current transmitters are 2-wired 4..20mA and some are 3-wired.
First question: My idea was using the Uvn onto the siemens input card for power. But they are using 35V??? Does anyone has an idea why they use 35V? I thought 24Vdc was the most common supply power in industry.. The current transmitters we are using has a supply voltage between 7 & 30Vdc maximum.
Second question: I am not a big fan if it comes to installing and wiring Siemens PLC cards. What components do you use for analog current measuring? For example: Wago analog interfaces combined with the siemens input cards. Or analog modules with profinet…
Wiring has to be easy, especially for the people that will to do the wiring in the cabinet. It should also be easy to change from a2-wire to a 3- or 4wire?
Attached a PrtScn of the Siemens manual
Thanks in advance
I think the answer is just no, but.... I have a program that I need to make a couple hundred changes to. The data is in DBs. I need to either...
29
12,313
Hi all, I'm not a Siemens expert (my forte is AB) and I need a little help if possible. I have a 315-2 processor and one of my input cards...
5,235
Dear All, I would like to connect 4 wire pt 100 connection to SM334-0KE00-0AB0 Unit Modules. In my hardware setup, firslty i configure...
9,045
Hey I'm looking for a solution to read a number of onewire temperaturesensors into a S7-300 PLC. Prefeerely through RS232 using a CP340 and the...
1,790
Dear sir. We are in the engineering stage of our project..I want to submit material submital to client.. In that complaince statement as per...
3,700
