Siemens 2nd HMI connection to PLC not in project
JDCROCKETT724
Jun 2010
Michigan
249
I have a TIA portal project with an HMI connected to the PLC in that project.
Is there a way to setup a connection to another 1500 PLC that is not in the project?
You use a device proxy. Look up Inter Project Engineering (IPE) in the help. Essentially, it creates an export file of all the 1500 information that the other project can connect to.
Alternately, you can use the S7-300 driver, with non-optimized DBs.
Hi, I have been looking on ebay for a while trying to find a good deal. Most are from overseas and i'm a little skeptical about purchasing them. I...
2,157
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
68
80
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
60
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
118
