Siemens 505 to Siemens S7
Rob S.
Sep 2008
Maryland
739
I may have the responsibility of migrating a Siemens 505 to a Siemens S7 . What is the Siemens 505 ? Is it from the old Texas Instrument days ? Is the code written much different ?
Instructions somewhat the same , or somewhat different ?
Thanks so much
Rob
How much I\o?
Can you post the 505 code?
Step7 does have a TI to S7 converter. It would be interesting
To see what would be converted
I have a interview with a company that needs this done , and I would just like to prepare myself a little . I have no idea what the code looks like. Kind of wish I did have the code before hand.
Thanks,
The 505 is the old TI 505. There really aren't a lot of similarities between the 505 and S7, except that they both wear a Siemens label... In the AB world, it would be analogous to converting an SLC5/01 or SLC5/02 to a ControlLogix L7x. The memory structure changes, the instructions change, ...
Quite often, when you're making this kind of leap, you're really better off just starting over. It gives you a chance to add new features, simplify coding, fix known issues, etc...
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,266
We've a 555-1106 with one remote base and three other PB devices. This base has a 505-6870 RBC, and three modules / IO cards. I am trying to add a...
1,582
Good day - I have scoured the forum to no avail. I have a Siemens 555-1106 rack with a remote base on RS485. It does not currently, but will be...
2,165
Stick a fork in it? Circa 1995 control system on a critical machine. Less than 100 Digital IO, less than 10 analog IO. I believe we can remove...
1,661
Hi guys, first time posting on this site. I'm a Maintenance Electrician and am having trouble understanding some ladder logic on one of our...
3,689
