Siemens 6ES7 313-5BF03-0AB0 High speed counter issues
DColley
Aug 2008
Sproatley
Hi, I am currently using a Siemens Simatic S7 313 PLC with built in high speed counters. The issue I have is that the counter appears to increase / decrease at random. i.e. quadrature encoder connected but not rotating. Has anyone experienced such problems, is the counting unit suspect to interference, the cable utilised on the encoder is screened.
Hello: Just posted a similar inquiry with regards to Rockwell HART master. Trying to figure out whether the Siemens offering is better. I need to...
4,773
I've been fighting a problem with this 8 channel analog input card mentioned in the title. I believe it's something I'm doing in the wiring but...
1,718
Why when i connect all the 8ch of Analog Input(4-20mA) into the 6ES7 331-1KF02-0AB0 module the 4-20mA reading is not correct. example the input...
2,940
We are trying to trouble shoot a Siemens IM 151-1 6es7 151-1aa03-0ab0 modual by the flashine LED but I can't find the documents for a flashing SF...
17,256
241
