Siemens 810D M-code assigning to an output.
rob0787
Nov 2006
New York
We have several CNC's that a German company built but went out of business. We need to add an output and have it assigned to M-codes that can be used in our G-code program for users.
We want M86 to turn on a PLC output such as Q41.7 and a M87 code to shut it off.
We have Step7.
Could anyone explain where an what we need to do to add this code? I know this answer could be lengthy but it would be appreciated!
Hello All, I want to connect to system control of siemens CPU 810D with STEP7 V5.1 SP6 but I couldnt.Who Can help me to solve this problem?
3,022
61
315
164
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
