Siemens 840-D PCU50 backlight
doyletuttle
Sep 2007
north carolina
Hi, Does anyone know if the backlight in a PCU-50 with Windows NT has a user changeable backlight, or is it something that I have to send in for service?
I can barely see the screen so I know that it is working, it's just that the backlight has gone out. Thanks in advance.
Yes it's possible
Have seen recently a Siemens PCU50 / OP12 where a service engineer has replaced the Cold Cathode lamp and added a seperate inverter with 12DV input. This was being run from a mains plug pack. I recently replaced the plug pack with a 24VD-12VDC (500mA) regulator (used extensively in trucks to reduce voltage for other auto accessories). Altogether a good fix, certainly more cost effective than buy replacement Operator panel from Siemens.
Hi I have an old machine that I recently got into the building that has a Siemens 840-C controller with Simodrive 611 drive controllers and S5...
1,530
hi all we are using a cnc lathe scoda sut 140 nc which is operated with sinumerik 840 c version 4 suddenly the machine turned the langauge to...
2,330
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
99
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
146
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
167
