Siemens / ABB combination
apetkov5
Aug 2007
x
101
Hi!
Customer have few Simatic s7-300 and control center with installed ABB IndustrialIT 800xA.
Is it posible (and how) to connect that s7-300 to 800xA and make SCADA for them on 800xA?
There is FOC between s7-300 locations and location of 800xA.
Tnx.
ABB 800xA is a hardware controller. Or am I wrong ?
How can you make a SCADA on a hardware controller ?
I think that there must be another SCADA software at the customer already. But it is not called "800xA".
Anyway, most SCADAs worth their salt support OPC, and you can use OPC with Siemens S7. Both Profibus and Ethernet.
it says "...installed IndustrialIT 800xA service pack 1..." - because of that i tought that 800xA is software
Mr JesperMP
He wants to hook S7 300 with 800M controller of 800xA DCS, using Profibus FO, I also want to know this, could you please highlight?
S7 to ABB HMI
Granted I only have experience with connecting Allen Bradley PLCs to ABB's OperateIT HMI platform (running AC800M PLCs) but you should be able to run a third party OPC Server (Like Matrikon) that has drivers for the S7 line. Then you would connect the ABB HMI to the third party OPC server to bring the Siemens PLC information in. In our case, which dates from about 2003, we used TOPServer OPC Server to communicate with our Allen Bradley PLC-5s. Tags were defined in the ABB OPC Digital and Analog Objects database that pointed to the TOPServer OPC server tags. Note if you type in www.matrikon.com, you go to Honeywell's website - Pull down the Solutions menu, then "OPC Servers and Products" is the Matrikon line. I'm not pushing Matrikon, there are other third party OPC servers out there that should also work.
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
455
Hi to all , can anyone explain to me how can i control DC and AC drives ( ABB DCS 800 and ACS 850 ) from a Siemens CPU using Ethernet or profibus...
6,887
i am new in robotics programming and configuration. this is completely education project talking to ABB robot with devicenet option irc5...
1,948
Hi I'm trying to read data from a ABB M2M from at Siemens S7-1500 plc by Modbus, however I can't seem to find the starting address in the M2M...
1,802
I have a Siemens S7 300 CPU 315-2 PN/DP PLC and CP 342-5. IM Module is configured via ethernet port. I have two profibus network. One on CPU and...
4,145
