phil
Guest
P
Hi all.
I have a CPU314 (no DP!) and a OP17. Is it possible to set the leds on the OP and read
the keys when both are connected over MPI ?
Both stations 'see' each other, because when I remove the cable, the OP generates the error : PLC address 2 not possible.
However I can't read the keys or set the leds... Do I have to use special functions blocks to initiate the data transfer or is this not possible ?
Thanks in advance !
Thanks in advance !
