Siemens cpu314 profibus cp342-5
jacokapp
Apr 2008
Port Elizabeth
35
i have a siemens cpu314(without profibus port) with a cp342-5 profibus card on the rack....if i try to add slaves to the network it shows them as inactive....(greyd out).Is there any special fc i need to use if i use the cp342-5 as master?
I never used a CP 342-5 for simple I/O but to access data consistently I had to use the DP_SEND and DP_RECV command. I don't remember which SFC numbers these are.
This must have been an old CPU to which you added Profibus DP I/O. In the future you should buy the S7s with Profibus DP in the main CPU because it is much faster. The CP 342-5 wastes a lot of time transferring data across the back plane.
Hi, I am using a Siemens CPU 314IFM with DI4xDC24V | AI4/AO1x12Bit module. I want to know the position of a motor by coupling a 10k Ohm...
4,003
Hi, I have CPU PLC S7-300 type CPU314 with P/N : 314-1AG13-0AB0. At the moment this type is DEFECT and I have SPARE with difference P/N, these...
1,693
I am new to this plc, and I have a problem with communication betwen the hmi tp270 and the cpu314c-2dp using mpi port. Do i need to set the...
2,355
I wish to know what drivers, devices or software are needed to connect a Cimplicity station with a Siemens CPU S7 314 (with CP343-1) by TCP/IP...
2,369
P
Hi all. I have a CPU314 (no DP!) and a OP17. Is it possible to set the leds on the OP and read the keys when both are connected over MPI ...
4,102
P
