Siemens CPU315-2 DP Current Outputs
Jordash
Aug 2012
Melbourne
I'm using a CPU315-2 DP and I can't find any information in the manual regarding the analogue current outputs, such as the addresses and which pins to use for measurement.
If anyone has this information it would be greatly appreciated.
Jordash,
Go to the Siemens support site and search for the cat numbers of the IO cards you are using, and download the manuals for them.
The answers are there.
The 315-2DP is a cpu and has no IO.
How do I get the cat numbers? Is this located on the actual PLC slots, at the bottom it says 332-5HB01-OAB0 is that the one?
Jordash,
On the siemens website I couldn't find a manual, just some technical specifications. I did find some documents for the
6ES7 332-5HB01-0AB0 from google but still i was unable to obtain the information I need.
The siemens website is not the easiest place to navigate round - they never make anything easy!
You will need to find or assign the peripheral output word for the card in your hardware configration in S7. Also in there check that the card is configured for the output you want.
Then you use the unscale function to send your analogue value out to the real world.
HTH
Andy
Info here page 430. It will have the pins. As for the outputs these are defined in your hardware configuration. Do you have a project is this a new project?
Dear Sirs, I had a problem with CP 343-1 with CPU315-2DP.I had newly add the CP343-1 Ethernet module to the hardware to allow me to access this...
2,639
I have never installed a brand new CPU before. But, I need to take an existing project from a CPU315 and put it in a CPU319 because we are...
3,121
Hi, I need to make a change in the Hardware Configuration of a Siemens CPU315-2 2PN/DP. But I'm not able to download the modified configuration...
2,027
Hi folks, I could really use some help - I am trying to connect CP340 with my PC by RS232 protocol. I need to send some characters to PC from...
1,902
Hi, I am a student and trying to wire a Siemens CPU315-2DP Analogue Module with a 0-10V and 4-20mA sensors. The Specs of the PLC are: CPU315-2DP...
6,547
