Siemens Drive Fault Code f.07453
JuanPLC74
Feb 2017
Houston
23
Hello Everyone,
I have siemens drive Cu310-2
At random Fault f.07453 happens,
Any experience with this fault ?
Could it be a bad encoder or wiring?
what has been your experience with his type of fault?
Regards.
I seem to recall that one when the mechanics and encoder resolution wasn’t set up just right. Are you using epos?
Can you do a screenshot of the mechanics and encoder data from Starter?
Thanks for the response,
ePos? I dont see that in the schematics,
also, what do you mean the mechanics? as in the mechanical installation of the encoder?
Hello,
It looks like we are having the same problem: but I cannot see the img-file of JuanPLC74 anymore...
Perhaps JRW still knows the answer: where was the problem in the drive software??
We have a lot of Siemens drives (Micromaster 440) on Profibus and I have noticed that just in a few months time I have got two drives which have...
9,228
1,684
We havea 100kw AC motor with HEIDENHAIN encoders ERM 280speed encoder. The motor works ok up to 500 rpm under closed loop control. Anything...
3,728
This is slightly OT but I hope some of our members who use Siemens AC variable frequency drives can help me out. I am trying to diagnose some...
11,967
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
245
