Siemens External USB Prommer
aloudermilk
Jun 2005
64
Does anyone know where there is a compatibility list of what software packages (obviously Siemens) the external prommer works with?
Al,
as far as I know, the Siemens external prommer (beit the parallel port one or the USB one) only works with Siemens modules and with Siemens software (Step5 and Step7, not Step7 micro). There's a (very) slight chance some third party software vendors making Siemens-compatible packages can use it as well, but knowing the protectionism Siemens normally shows I seriously doubt that.
Kind regards,
Hi there, So i have the siemens comfort tp700 hmi. I want to print using printserver and laserjet, but is there any way that i can change the path...
1,578
Hi Friends, Im learning about PLC using SIEMENS S7-300. Im a biginner for PLC. What are the types of external modules can be attached to PLC like...
1,748
Dear All We have SIEMENS PLC S7-412-3H redundant system having remote I/O modules connected with Profibus. During commissioning when we Power up...
2,312
Hi, I want to run a program on my PLC without download it into the PLC. The error message I had is :not enough memory on the memory card. Did...
4,063
Hi all, I'm new to Siemens and looking to use an s7 with 3 racks. I have one simple question, does the im361 require external power, or does...
4,234
