Siemens Failsafe Signal Modules
PeterW
Jun 2006
Calgary, AB
2,531
For the first time I'm working with the failsafe safety modules and one little thing is annoying me in that there appears to be no information.
When you assign the addresses to the cards, there is always an output area associated with the input cards and vice versa for the output cards.
When you click in hardware profile to edit the symbols, only the inputs turn up.
I cannot see where you would use the outputs, reading the manuals they only mention the outputs in the tech specs stating how much of an allocation.
Anyone know;
Why they allocate outputs?
and How and why do you use them?
Peter
Im sure I have some detailed info
but the short of it is that it is your F safety process image
You will need to monitor the "pass_out", "qbad" etc
The Safety integrated system uses the extra I/O address space for the send/receive of a CRC based telegram. Each end monitors the telegram and if a problem is encountered, the plc can report it and the safety outputs can go to their fail safe state.
Thanks, mystery solved.
Wish they state that in plain site, had me wondering if there was supposed to be something important I should be doing with it.
I have a Siemens S7-414 PLC that has, among other things, one ET200SP rack that has one safety F-I/O card (6ES7136-6BA00-0CA0) (two emergency...
1,573
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
88
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
240
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
100
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
159
