Siemens G120 VSD flying start?
Reenigne
Dec 2016
kent
I have a G120 PM140 IP20 Power unit with a G120 CU240E-2DP Control Module driving a 45KW motor with a fan directly attached. The fan is in ducting which has dampers installed after the fan.
Following some hard facing of the fan (which has added weight) the following errors keep occurring intermittently when staring:
A07409:U/f control, current limiting controller active
A07910:Motor overtemperature
F07900:Motor blocked
Due to the nature of the install the fan does free spin (in the correct DOR). However there is no flying restart (p1200) set up.
This parameter has never been set- but could the hard facing of the fan have highlighted this issue?
is there another explanation for the error codes?
Any advice would be greatly appreciated.
Have you tried running the Basic Commissioning wizard, the motor loadings etc will have changed due to the extra weight of the hard facing.
The drive will adjust its parameters if you run the wizard.
Hi All CPU 1517F-3, Drives G120C Working on a project that is under development, so more IO will be added as we go along, to keep my drives out...
677
Hi All I have done the commissioning wizzard on the drive with Tia portal V15.1 and all good , but once i go to acceptance test and click on STO...
2,230
So I have some Siemens drive that I want to examine the existing setup parameters. From the Operating Instruction manual it shows a "PC...
2,394
I have a project where I need to get the torque reading from a G120 drive. I have communications setup over profinet. I am currently using the...
4,620
Going to be Connecting a Siemens G120 over Ethernet to a Modicon CPU. Programing in Unity Pro. I am having a really hard time finding any sort of...
2,252
