Siemens Line Module to supply distributed Motor Modules
Kataeb
Jan 2007
www.livelovelebanon.com
636
Can we use a central Active Line Module to supply with 540VDC power, Sinamics Double Motor Modules installed in other cabinets many meters away? Each cabinet containing five to ten modules.
Which protection should be used on the way? which cables?
I cant find max length in the manuals.
But Ive seen somewhere....seem to recall about 5 meters?
I know it can’t be very long
You find the specs?
Also make sure the wire insulation is at least 1000v
Don’t forget the dc link adapters and 24vdc adapters
Hello Members: I am trying to control the Siemens S120 ActiveLine module with the Beckhoff EL6731 as Profibus master. I just want to switch the...
3,136
A have a 12 axis S120 system where I have 6 axis on one CU and 6 on another. They all share the same Basic line module. The first CU though is...
28
17,214
86
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,245
Hello guys, Im using a siemens with WINCC in a computer and need to import to tag´s data fom a specific row in a SCV file, i have a working...
1,732
