Siemens Media Redundancy Manager Role
JDCROCKETT724
Jun 2010
Michigan
249
I am setting up my first ring with siemens. There are two manager roles to select. "Manager" and "Manager (auto)" What is the difference between these two roles? I am having trouble finding documentation on what they are.
Hi, the Manager (auto) lets the switch check if there is another MRP supervisor in the MRP ring, whereas the Manager will attemtp to become the manager without checking. If you only have one MRP supervisor it does not make any difference which setting you choose.
Hi, I have a problem with Media Redundancy. My config in test is like this: When I disconnect 1 side, the red lights goes on and the slave...
2,559
37
302
163
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
