Siemens Micro/Win install failure
glenncovington
Apr 2002
Gloucester, VA
303
Hello all. I tried installing the Siemens MicroWin 4.0.0.81 demo on my Dell Latitude D630 with XP SP3. The install bombed before it completed. I then tried to uninstall through the windows control panel and it failed to uninstall. Everytime I try to reinstall it asks do I want to completely remove all files, like it is still trying to uninstall and then I get the attached message. Anybody know how to clear it off my machine to allow for a clean reinstall?
This might sound daft but has worked for me for various install problems. Login as a different user, if needed create a new user just for those problem installs.
The the always stuff.
Switch off Antrivirus
Clear Temp folder
Install as administrator
Shut down and restart computer
Thats all I can think of at short notice.
Bryan
Revo
There is a small uninstaller utility called Revo. Very useful.
Very compact.
Try Googling "revo unistaller".
I wish I could post the link but I am on my phone!
I had the same problem few years ago, I had to reinstall Windows.The best solution is to quit with Simatic, throw it in trash, and use non-buggy Omron Cx-one.If you even install it (full working version), you will have many problems with PPI cables.
manny problems happened when peoples upgraded to XP SP3 when the soft was already installed on SP2 but changing for another brand because of that is just a politic option to my eyes.....And by the way with Omron......If you had said one of the big 3 ok you got something maybe with the changes but.......
All soft has their problemes and the one connected to windows isn't 100% others responsability. SP3 install a lot of protection that sometimes reject programming soft....
I do about 50 projets a year with Siemens soft and yes i got some bugs but all the time solved. Usually when i get bored from Siemens, i got a job to do with other brand from the big 3 and sometimes from foreingh and i'm always very happy when i got back to Siemens ...!
Demo version is does not support SP3. Go get a newer version from Siemens Rep/Distributor. You'll be happy to program like an adult.
Call the Siemens Hotline. They'll walk you through cleaning up the registry to fix it. They are very good, I call them all the time.
Hi, I'm new to this forum and have been programming plc's for about 2 years now. I have done programming and mods on different small systems and...
3,344
Just when you think your problem is solved..... new problem! My Siemens rep came through with with the Step7 Micro/WIN software I needed for a...
6,933
I have an opportunity to quote an HMI project for one of my customers. It's a small project, and the customer is not the type with deep pockets...
24,881
Am I correct to think the Offset is the start and the Number of Elements the end? MB Offset = 14, Number of Elements = 18 Means, MB 14 to MB...
1,677
Can the status of the unit be saved in the L memory so after the unit experiences a power failure, the unit starts up in the last saved status?
1,713
