Siemens Step7 Micro/WIN installation issues
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
Just when you think your problem is solved..... new problem!
My Siemens rep came through with with the Step7 Micro/WIN software I needed for a project. Here's what he did:
1. Told me to download the Service Packs 8 and 9 from the website.
http://support.automation.siemens.c...lib.csinfo&lang=en&objid=58523240&caller=view
2. Sent me Microwin.exe file to use as a "key" to allow the install (see the bottom of the page, above, for the instructions: "INSTALLATION INSTRUCTIONS with a simultaneous change of the operating system"
I'm using Windows 7 on a 64 bit laptop, so SP9 is the correct version.
Gmail wouldn't allow the microwin.exe file to email, so he renamed it to .txt, and I renamed it to .exe when I received it.
I "unblocked" the downloads in Windows 7, then unpacked the zipped SP8-9 download.
I started installation (setup.exe) and the installer started looking for the microwin.exe file. It says it cannot find it, and asks for me to locate the folder where it's located. I made a folder with only that 1 file in it and highlighted that folder. It says it cannot find the file and terminates installation.
The Siemens rep doesn't know why this doesn't work. I can't find it on the internet, either.
Any thoughts on why this isn't working?
4UnableToFind.png searching.png SelectDirectory.png 3Siemens.png FileLocation.jpg
I do not at the moment. The rep is trying to duplicate my experience at his office with a different laptop.
....and he just called me. It works for him. So, he's sending me a disc to a branch office, and I'll pick it up after a service call tomorrow.
I have an opportunity to quote an HMI project for one of my customers. It's a small project, and the customer is not the type with deep pockets...
24,858
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
147
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
543
Hi, I received a Step7 Backup from my client and tried opening this backup but it won't open as there seems to be files missing from the backup...
3,021
