Siemens Modbus PN block using S7-314 and RMC30
DLMUK
Jun 2013
Southampton
311
Hi all,
I have been struggling for a while trying to get Modbus TCP/IP comms setup using the MODBUS_PN block with an S7-314. I was using a Netgear switch, Siemens told me this was most likely the cause of the problem so I have replaced it with a Siemens XB108... surprisingly it hasn't solved the problem.
I am adamant (not adam ant) that it is a config problem. Has anyone got any experience of setting up the MODBUS_PN block or using an RMC30?
I currently have the RMC30 setup as a MODBUS Server, and my S7 setup as a MODBUS Client. IP addresses etc match, I can open ports 502 using cmd telnet session.
When i view online TIA portal shows that there is a connection established between the two but I cannot access any data!!
Thanks,
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Hi all, Happy belated turkey day! I have an ET200SP PLC with serial unit. We read out date from two energy meters using modbus RTU. We run a...
631
A customer site has 26 Nicotra Gebhardt EC PFP roof mounted ventilation fans. Control and monitoring is to be via Modbus RTU withing a Siemens...
545
Anybody have experience monitoring and controlling systems over Modbus using one or the other of these devices? Would like to start an exchange to...
408
