Hi all
I have some problems in exporting recipes data set on a USB memory stick in CSV format(Siemens MP277).
The goal is backup the recipe files in a USB memory
Recipe data are stored in the flash memory of the MP (but i tried also with an external memory).I've 5 recipe file in my project, with 32 datasets each. I need to find 5 folders, with 32 CSV files each after the backup procedure.I've created a script, and in this script there's a for-next cycle in which I export the current dataset:
This code works, but very very often it happens that the system function ExportDataRecords return 12 (error).
Is there a limit of memory which can give such a problem? Should the usb memory be formatted in particular way? Till some time ago I had only 3 recipe files and the code worked better (I had had this problem but very rarely). Now with more recipe data the code WORKS very rarely....
I tried to use USB memory for storing recipes (and not flash memory) but nothing change. I've seen that the total dimension of the recipe files (NOT the backup) is about 64 Kb (i saw it when i stored recipe in USB memory....)
Does anyone have some experience on this?
Code:
For index=1 To 32
ActualDatasetExportingUSB=index
StateExportProductionRecipe=0
StateExportFillingGains=0
ExportDataRecords "Production recipe",index,"\Storage Card USB\ExportedRecipes\Production Recipe\dataset " & CStr(index) & ".CSV",hmiOverwriteAlways,hmiOff,StateExportProductionRecipe
Do
Loop While StateExportProductionRecipe <>4 And StateExportProductionRecipe <> 12
If StateExportProductionRecipe =12 Then
Exit For
End If
ExportDataRecords "Filling Gains",index,"\Storage Card USB\ExportedRecipes\Filling Gains\dataset " & CStr(index) & ".CSV",hmiOverwriteAlways,hmiOff,StateExportFillingGains
Do
Loop While StateExportFillingGains <>4 And StateExportFillingGains <> 12
If StateExportFillingGains =12 Then
Exit For
End If
... (and so on, for each recipe file)
next
