Siemens Netpro errors: the object has already been deleted
Can you do a save as reorg slow?
Then look at netpro
It works... Thank you
Remains some minor warnings.
Warning: The PROFIBUS addresses '14' and '15' of the active station (Master) in PROFIBUS subnet 'PROFIBUS Net 1' should not immediately follow each other.
Warning: On the PROFIBUS subnet 'PROFIBUS Net 1', there are additional active nodes in other stations that also have to be reloaded.
Hi Can anybody please explain how I can export the connections from Netpro and import to another project but I require only the connections...
4,433
For commuincation between Citect and Siemens through CP5611 and MPI protocol I need to create a PCstation in NetPro and connect it to my...
6,615
87
322
167
