Siemens OP 27 Communication Problems
djjavens
Mar 2008
Minnesota
Hello,
I have a Simatic OP 27 connected via MPI to an S7(315 cpu), which inconsistantly will make communication with each other. Our equipment is not 100% dependant on the OP, however we are not able to calibrate or view any input signals without it. I have tried different things to aliviate the problem such as: changed the MPI cable and connectors, checked port settings, changed backup batteries, and cleaned the dust from the units. What we experience is not a communication fault, but the OP never completes the startup sequence. It tries to re-establish communication with the PLC continualy by in my estimation "rebooting". I am wondering if anyone has experienced this problem and if so, what was the remedy? I have contacted the machine manufacturer, but since the OP 27 is no longer manufactured, they want us to upgrade to the OP 270, which I believe is out of service as well. If this is the only course of action, are there any other sugestions for HMI's that would work with the programming in the S7. I would rather not have to reprogram the entire system, as I do not have any of the originals.
Regards,
Dean Javens
As you describe it, it sounds like the OP27 is about to bite the dust.
The current replacement for the OP27 is OP277-6. It should be possible to migrate it reasonably easy. In any case, you need the original Protool project.
Hi, I would like to know if one can use a 6ES5721-0CD20 instead of 6ES5721-0CE00. If anybody has information or datasheets for 6ES5721 - 0XXX0...
1,772
I have a Siemens 315-2 PN/DP PLC connected to a TP177B and MP377 touchpanels thru ethernet communications. I am using 2008 Win CC Flexible...
8,554
Hello! Have anyone in here used the Siemens CP340 RS232C communication processor (6ES7 340-1AH01-0AE0)? I'm trying to figure out how to use this...
42,340
121
Hello Guys, I want to establish profinet communication between siemens plc and my system using python programming. Which python lib can i use to...
388
