Siemens simatic s5 : CC - EU communication problems
kalpal
May 2015
london
17
I would like to know if one can use a 6ES5721-0CD20 instead of 6ES5721-0CE00.
If anybody has information or datasheets for 6ES5721 - 0XXX0 please forward it to me.
Any information or help is most appreciated.
Regards
KalPal
The 721 cables should all be the same (except the length). A Siemens catalog from 1988 (here: http://www.automation.siemens.com/salesmaterial-as/catalog/en/st5098_e.pdf ) on page 3/85 lists the different part numbers and lengths.
You've checked that the terminator is installed at the last card in the line, yes? It's been a while since I did S5, but I remember that's an easy way to not have things work.
thanks
Thank you Kalle and Ken for your replies.
I have gathered information from Siemens AG that both the cables are same but different lenghth. That rules out the cable problem. I am looking at ordering a new power supply and rack. will update as soon as i track the problem.
We have an old system controlled by a siemens plc s5 with order no. 6es5 102-8ma02 we want use for this system operating panel siemens op25 but so...
2,880
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
502
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
551
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,070
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,268
