Siemens OP15 AG
DexterIt
Oct 2010
Italy
21
Hello friends. As in the title i have this OP15 panel on a line for more than 15 years,and now a couple of buttons has started to fail due to long activity.I found a replacement for him,and i was able to transfer from the panel and back to the panel with no problems.It asks me level 1 password that i know it is 100.I can change the protocol used for the SS1 if i need but it worked so far.Now my problem is that on the panel i want to change,after i try to put it in transfer mode he resets very quickly.Same story with the level 1 password,but he never stays in transfer mode,he quickly(i mean i barely have time to read it)display this line:
"ANLAUF NACH COM TEXT ABBRUCH",that i understand he say it is restarting.My guess is that maybe i need the supervisor password to enter in transfer mode.I am using the original PG from siemens with Step5 program.
Any help is appreciated.
Ok guys..i solved the situation.It seems like 1 or more of the buttons were pressed and the panel after entering transfer mode would exit it immediately if 1 button is pressed.I had to unplug the button ribbon from the pcb to make it stay in transfer mode.
Dear experts, I have a siemens OP15 operator panel. I need to change the language. I had found the process and first of all I need to log on to...
1,780
I need the program loading method (Step by step procedure)of PC->PLC and PLC->PC for SIEMENS Coros OP15. Any one please help me to do this...
4,658
I was wondering if there is a standard password for a siemens op15 panel. The battery died and the power was off and it is now in German and...
2,230
Does anyone know if there is any way to upload the configuration from an OP15 that was programmed with Protool. Tried uploading from Protool...
1,965
I have old OP15 program file with name "FFFF.O15". What the name of software I can use for open this file?
2,819
