Siemens Op3 Problem
mehkocak
Jan 2005
58
firt of all thanks for your answers;
I need information about how can I upload the program from op3.As I know I can manage that with protool and can you tell me the connection cable to op3 with protool.
thanks
You can download to most OP's/TP's/MP's using this cable, that is if your laptop still has a serial port (RS232 or COM port):
...but I'm not sure about uploading from an OP3. Maybe one of the veterans on this forum can answer this question.
OP3 is configurable from protool or protool/lite using simple rs-232 cable ... on one side is typical 9pin D-SUB (pc) on second there is RJ12 (6 pin connector ... very similar to RJ45, which also known TP10/100)
or, you can use OP3's integrated MPI interface as well
G'Day all, I have a problem that I just can't seem to get rid of, Equipment: S7-300 312 Cpu with MMC. OP3 HMI Software: Simatic V5.2 Step 7...
7,640
do you know any supplier for the op3 membrane? we only need the membrane with keys, as a spare part...
1,240
I have OP3 and i want to Upload data from OP3 to PC , i'm using Protool , and i can make Download to any New OP3 , but the one that contain Data ...
1,642
I am having a simatic op3 siemens hmi, in order to communicate with pc what are the cables I should purchase, do I have to install any drivers...
2,200
by trial i can change the OP3 ProTool screen to OP73 WinCC Screen and download the new screen to OP73:wizard:. I want to ask if it's possible in...
4,585
