Siemens Pack & Go file
baxo
Dec 2008
szentes
Hello Everybody!
I am in trouble with the following situation:
I get the Pack & Go file for Siemens comfort panel TP700.
The firmware of the comfort panel in the Pack & Go file and a new comfort panel are different. (I have a newer firmware panel).
Because of this I can not upload the Pack & Go file into the panel, I get a fault message about the different firmware.
I have no chance to get the source program and modify the device version.
Have you got any idea how can I upload the Pack and Go file in this case?
Thanks in advance!
Download ProSave to upgrade/downgrade firmware. Perhaps its enough to install ProSave then the PackAndGo program might find the firmware. Newer versions of pack and go can handle Firmware upgrades but you must have the firmware file for this to work otherwise use the ProSave program before PackAndGo program
Hello to all. I'm trying to configure the ModBus connection between 315-2PN/DP and Sentron 3200 pack, but without success .. I can not even...
2,596
Hi I am trying to pack and go a project for the first time. I have a set of MP terminals in spain and need to send files to the commisioning...
9,608
Did anyone has installed Step 7 v5.4 Service pack 1 and 2 ? I just installed service pack 2 and i dont know i i should intall service pack 1 ?
5,047
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
297
