Siemens Wincc flex pack and go problem
cjd1965
Apr 2007
UK
1,659
Hi I am trying to pack and go a project for the first time. I have a set of MP terminals in spain and need to send files to the commisioning engineer
1 shows WinCC Version
2 shows transfer dialog box
3 shows my error
Am I being stupid or is this a bug?
I may have to DHL a laptop to him if this doesnt work.
I thought I could back these onto a SD card and restore on the terminal but it isnt an option on Pack & Go
Cheers
3 shows my error
Cheers
Not sure, this may be a stupid answer but you have to be on-line to pack & go from what the errors show.
Dont think so see the attached PDF from Siemens
The intention is to be able to send a file to a remote person who hasnt got the software
[FONT=T3Font_0][FONT=T3Font_0]
[/FONT]​
[/FONT]​
[FONT=T3Font_0][FONT=T3Font_0]The relevant hardware conditions are fulfiled on the Transfer PC depending on the transfer.
A requirement, from the pdf.
Can you go on-line with the OP?
If yes, pack & go should work.
[/FONT]
[/FONT]
It works for me with the same settings, except that I do not use the STEP7 project directory. Do not use the STEP7 project directory, but some other independent location. But I am not sure if that has to do with your problem.
You do not have to be online with the panel, but maybe S7ONLINE must be set to TCP/IP(Auto) to macth the transfer setting.
Confused
I dont have a panel here.... is that the issue? I thought the idea was to be able to generate files without the need of a local panel so you could send them to a remote panel
Jesper , Thanks but I already tried an alternative folder before I first posted
Is there any other alternative method for emailing a project and a remote user can store it to the panel, say using a SD card?
S7ONLINE... do you mean the control panel tool for selecting the comms option?
It should work. I have done it with an MP277 KEY, and I was not online when I generated the Pack and Go file.
Maybe it is some other issue with your PC. Can you try on another PC ?
There are two other ways:
1. If you have a similar panel at hand, then transfer to that panel, and use the Bacup/Restore on the panel to save to an MMC card. Then send an image of the MMC card by mail, and reverse the steps at the other location.
2. Or, again of you have a similar panel at hand, transfer to the panel, and use Prosave to make a .psb image file. Send the .psb file by mail and reverse the steps at the other end. If the firmware version is different, it may be necessary to perform an OS update, which can also be done with Prosave.
Update
Hi
I still couldnt get it to work. I have sent my laptop via courier which is great nuisance.
It seems that WinCC Flex tries to download to a panel even though I have pack & go ticked..maybe it is a bug
Cool, the boss bought me a long awaited new HP Probook Windows 7 laptop with a serial port. My (not that old) Siemens software isn't allowed to be...
19,859
May be a stupid question, but I'll give it a try... For a customer of us we need to use a Beckhoff panel. Because the customer is not happy with...
6,827
Can some one please help me with the following questions on: Siemens S7 – 300 PLC and WinCC Flex 2007 HMI (Simatic touch panel) Does any one...
12,468
Hi, I'm using some variables of KY data type (two absolute numbers, one byte each, in the range of 0 to 255), if I want to write the two number...
3,262
Here is a good example of using WinCC Flexible and Step 7 with source code. Problem The technological task to be solved is based on a...
5,505
