Siemens WinCC Flex on Beckhoff panel
userxyz
May 2002
any
2,768
May be a stupid question, but I'll give it a try...
For a customer of us we need to use a Beckhoff panel. Because the customer is not happy with the lifetime of a Siemens panel. It's for the food industry. Beckhoff panel: CP7702-1400-0030.
We want to keep working with WinCC Flex. Because the software is allready been written for the application.
On the Beckhoff Panel: XP is installed.
So: WinCC Flex with a tag license will do the job.
But, isn't it possible to load an IMG file from an MP377 to this panel, to eliminate the tag license...
1st, if you could just copy an image from one PC to another, it would be illegal.
2nd, Siemens MP panels run on Win CE, not Win XP.
3rd, the software on Siemens MP panels are taylored to the hardware. The MP panels normally use some non-i86 CPU, such as an ARM for example.
So, just buy a WinCC Flex PC RT license.
Beckhoffs panel PCs are expensive.
WinCC Flex RT 128 tags is cheap.
k
1. Yes you're right. These IMG, ment for OS update are only legal on Siemens panels. I agree.
2. Yes I know, CE or XP embeded, this doesn't matter, as long as I can run a runtime.
3. That's also what I tought, that it goes together with their panels, only for their panels.
First panel to convert: 942 tags. 128 tag license (around 400 euros) will not be enough. These licences are very expensive for PC runtimes. That's the reason for my questioning. Siemens also has IP66 inox panels, but the customer don't want Siemens in the house, he kinda hates them. Donno if Beckhoff will do better in the wet environement.
Thanks for the reply,
Regards,
Gerry
As Jesper said, it's not possible.
Just change the device and get the RT license, doesn't cost that much, if the customer wants it, he needs to pay for it.
We have several Siemens OP's that have been operational for several years now, and this is the food industry. Yet we don' have any issues with the lifespan. Did they say why the panels keep dying?
Close to 1000 tags would be necessary for a not-so-small project.
That, or some tidying up could reduce the tag count, or pack the tags as array tags.
I would definitely consider to only install the screen in the plant, and then connect the screen to the PC via a KVM extender. The PC can then be in a central PC room or control room.
Well
Well,
Indeed, we gave the panels to an electronic company in Belgium to check why they don't live very long.
After 5 years they die, that's the reason why he hates them.
Donno why yet, when I know more I'll place it in here. It must be something in the power supply section...
If the panels are PC RT, then you already have a license.
Even if the panels die, you can still reuse the PC RT license on another PC.
edit: Like suggested before, if you place the PC in a central control room, you can easily supply it via a (good quality) UPS. That will take care of overvoltages in the supply voltage.
Jesper
Thanks for the tip, but I think I'll go for Beckhoff panel + PC runtime 2048 tags. It will be not much more expensive then the MP377 15".
I just tested this on the Beckhoff panel:
Installed WinCC Flex Runtime
converted my panel to PC runtime and compiled it
copied to the beckhoff panel and opened the fwx file
resolution was not right at first, but after correcting this, very good screen quality
Cool, the boss bought me a long awaited new HP Probook Windows 7 laptop with a serial port. My (not that old) Siemens software isn't allowed to be...
19,861
Hi I am trying to pack and go a project for the first time. I have a set of MP terminals in spain and need to send files to the commisioning...
9,587
Can some one please help me with the following questions on: Siemens S7 – 300 PLC and WinCC Flex 2007 HMI (Simatic touch panel) Does any one...
12,469
Hi, I'm using some variables of KY data type (two absolute numbers, one byte each, in the range of 0 to 255), if I want to write the two number...
3,262
Here is a good example of using WinCC Flexible and Step 7 with source code. Problem The technological task to be solved is based on a...
5,505
