Siemens PC Adapter USB on VMware Issue
gav_33
May 2007
Malacca
Anybody have failed and solved the issue of installing Siemens PC Adapter USB V2.0 driver software on XP mode running on Windows 7 using VMware?
It just halt during installation and stay hang forever. Btw, it works on everywhere else except this.
Thank you.
I mean running Win XP as guest operating system on Win 7 using VMware. The driver software just won't install in my case.
I have search several sites, common issue encountered with no solution yet.
Just hoping if anyone here have any random idea for me to test out.
You have to unpack the USB Adapter 2.0 software inside the Guest, and run the installation software. When that has finished you can insert the USB Adapter in the host and connect it to the guest.
Do you do it in this order ?
I have had a similar issue with the USB prommer, and in the end I had to scratch the VMware image and start all over. I had done the installation in the wrong order, and it had entered a sort of catch-22.
Not sure if that is the case for you.
You could try to load a fresh VMware image and start all over.
Is too tedious to do so, I have quite a number of software which have been well configured. But if that's the last resort, I'll still try.
Did you finally manage to installed the USB adapter software in XP as guest OS on VMware???
I know. But it seemed similar to what you described.
The installation of the driver started, but the progress bar went to 99% and stopped there.
Only starting all over with a completely fresh Win XP image sorted the problem.
I connected s7 300 plc to pc via siemens mpi usb adapter.I used simentic manager and view the data.It is working with simetic manager.But i can...
3,030
Hello everyone, I have a new Siemens PC-adapter usb but doesn't work in accessible nodes. If i go to Set pg/pc interface pc adapter auto...
2,589
Hello everyone, A few months ago we purchased the MPI-USB adapter Siemens cable, which came with an USB to MPI module cable, the MPI module, and...
7,790
Hi folks - I'm setting up a central data historian at a customer's plant. I need to get data out of an S7-300 but the only port free on the rack...
5,059
Hi, l would like to find out if the above mentioned cable can work with windows vista ultimate and business.How much does this adapter cost.Find...
2,721
