siemens Pc adapter usb
pong10
Nov 2011
Cavite
Hello everyone,
I have a new Siemens PC-adapter usb but doesn't work in accessible nodes. If i go to Set pg/pc interface pc adapter auto properties and start network detection it working. what are the possible problem?
thank and advance
Thanks KAJ,
Now is working, I need to select manually the SET PG/PC adapter either MPI or Profibus. I think my adapter is defective.
I connected s7 300 plc to pc via siemens mpi usb adapter.I used simentic manager and view the data.It is working with simetic manager.But i can...
3,030
Anybody have failed and solved the issue of installing Siemens PC Adapter USB V2.0 driver software on XP mode running on Windows 7 using VMware...
7,009
Hello everyone, A few months ago we purchased the MPI-USB adapter Siemens cable, which came with an USB to MPI module cable, the MPI module, and...
7,790
Hi folks - I'm setting up a central data historian at a customer's plant. I need to get data out of an S7-300 but the only port free on the rack...
5,059
Hi, l would like to find out if the above mentioned cable can work with windows vista ultimate and business.How much does this adapter cost.Find...
2,722
