alanyap
Hi guys,
currently i'm doing a project requires using PID controller, since i'm very new to siemens PLC CPU315-2DP/PN. i would like to have some guide from u guys.
My PID controller receives an Analog input from Temperature sensor, the PID controller will control an servo actuator with feedback of the current position.
The problem is, how can i get familiar with siemens PID controller settings and going head on to the programming, the other thing is, the servo actuator is controlled by 2 digital signal output after getting the feedback from the PID controller, which i need to use something like continuous signaling block.
But i would like to study and understand how those stuffs works as the first thing as my basics so i handle same situation next time.
So, did anyone of you guys can guide that i should start study from which direction??
Thank you!! And have a good day..
