Siemens: PID_Temp Override control
BVG
Apr 2012
Ghent
Dear all
I am working on a little project where i want to use the Function Override control with PID_TEMP(See attached).
You can compare the Example in the TIA help file with my setup:
Input_1: Process control temperature 600°C
Input_2: Maximum Temperature 900°C (close to heater)
In stable conditions there is a temperature loss +/-150°C between Input_1 & 2.
When heating up input_2 reaches 900°C in +/-15min. Where input_1 will take more than an hour.
That is why I want to use the override control but the problem is I don’t know where to start to tune the 2 PID controllers in an Override control.
I am looking for a guideline(hints or tips) how to get the best possible control for such “slow” process.
If you need more info let me know! Thanks in advance
Hello all, A group I am involved with is just completing converting a Siemens APACS control system over to an RSLogix PLC. The subject came up of...
1,217
Hi, Have problem with getting PID to work. Have been using 4x different programmers on siemens, not one could make PID to work as I want. Problem...
1,758
Urgent, Commissioning deadline. I am using CONT_C in a function block. I call the FB in a Cyclic Program (OB32). when the PID is in manual I...
3,323
I'm trying to program the PID function of a G120 drive using Starter. The PID output looks good but the "limitation active" LED is always on...
1,661
Can any one help me regarding how to give set point via field bus for control yasakawa a1000 drive while it is running on PID operation. Also i...
1,484
