Siemens PLC S7-300 and Step 7 software
sodonnell
Feb 2008
Rock, WV
I am using a Siemens s7-300 PLC and using Step 7 software to reach it. However last week I could communicate with the PLC and change online and offline status. This week I cannot get to the PLC in in way not even with a ping from another computer. I am reciving a message numbered 33:16656 and have looked it up but the instructions. 33:16656 is...Online: Connection could not be established. The connection partner is not responding. Power has been turned off to the driveat least once in the last week. ANy answers would be appreciated.
Since you mention ping I assume you are trying to get to it over ethernet... Do you have any lights on the CPU or the CP343-1 module (mainly red or flashing) - do you have a link light when you are connecting from the PC to the PLC? Are you using a cross-over cable or a hub or switch? Has the IP address of the PC been modified - any virus or firewall or windows SP's installed? Check what the settings in Simatic Manager -> Options -> Set PG/PC....
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
692
Is there a version of Siemens software that can be used to view only the installed program logic and diagnostic buffer to determine system and bus...
2,096
Dear Friends; We have a BOBST 1228 flexo printing machine having Siemens S7-300 PLC (6ES7 318-3EL01-0AB0) and Lenze 9300 and 9400 drives. The...
2,315
I set the Date and Time of the S7 300 PLC equal to that of my PG. But after a few days I found that the date and time were not what they should...
1,919
Hi Can any one give me some of sample project file for Siemens S7 300 PLC that I can practice at home. Thanks in Advance
2,799
