Siemens PLCSim
silva.foxx
Dec 2004
North Wales; always West to England!
519
Hello chaps (& chappesses)
I have a S7 program with a 313C-2DP and an ET200S IM151/CPU.
In the sim I try to download the ET200 but get the following message:
Download (288:47)
Unable to reach the module IM151 / CPU via the online interface.
followed by;
Download (13:4337)
Unable to establish a connection to the module IM151 / CPU (R0/S2) in the station SIMATIC 300 ET200
I've tried the Help that comes up with the message and tried manipulating the Set PG/PC Interface but I'm just unable to get it working.
Is it that the ET200 is on the Profibus and PLCSim can't simulate that?
Please... any help would be appreciated.
Thanks in advance - regards; silva.foxx
Exactly.
This is THE problems with PLCSIM.
You have to copy your project to another project, then change the IM151 CPU from DP to MPI.
If both 313C-2DP and IM151 are in the same project, you have to select an unused MPI address (3 maybe). Then in PLCSIM you have to set that same MPI address.
When you are done, you copy the project again, and change the IM151 back to DP.
Hello guys, Need some help on siemens plc simulator. I am trying to download my trial project but it cannot find a controller to connect to. The...
5,357
Hi, I am trying to communicate with Siemens S7 PLCSim through InTouch (Wonderware). I am running a Windows 7 VM on a MacBook... I have Simatic...
5,857
I am currently working on a sizable project involving Siemens PCS7 on an H-system using WinCC for graphics. The project is still in development...
5,490
Ok so I know that SIMATIC S7-PLCSIM is out there to act as an emulator if you don't have a physical PLC to write and test programs with... but it...
8,743
I've got a nasty non-linear control loop problem to which I think I have a solution, but I need to be able to thoroughly test it and if possible...
3,348
