Siemens Pro Tool Pro Problem
jvjr
Oct 2008
PA.
96
I have a 315-DP2 PLC connected to a Siemens PC577 12" touchpanel PC running Pro Tool Pro (last and latest version) through profibus. Additionally I have a Delta motion controller also connected via profibus. On the PC577 I also have Step 7 version 5.4 loaded. I have no problems transferring data between the PC577 ( while Step 7 is running ) , 315-DP2 and Delta system. However when I put the PC577's Pro Tool Pro into Runtime I can not display the information the PLC has stored on its datablocks even though the Pro Tool Pro software says I am connected. If I use "M" memory bits or data it is fine the data is transferred between the touchpanel and PLC no problem. I am stumped. I have to work Sunday because of this problem. Anyone have any suggestions. P.S. I have worked on several similiar Siemens systems and never had this problem....
I am having trouble using ASCII text with the Allen-Bradley DF1 driver in Siemens ProTool/Pro. I am using a TP270 – 6” and an Allen-Bradley SLC...
5,474
Does anyone knows how to activate API function in Protool Pro? I want to activate WAV files (using VB scripting) in Protool Pro, using a PC as...
4,892
I am using Protool for the first time and I want to define different password levels. Protool supports only one password but it has an option to...
5,375
I would just like to take an informal poll. Over the years I have worked with various PLCs. Most of the manufacturers produce satisfactory to...
6,889
I have a project using Pro-tool Pro on a Siemens Panel PC that talks to serial devices through the PLC. I find this very cumbersome requiring the...
6,427
